New to me buggy!
- 74BuckinBronc
- Contact:
Shows you what I know on the beef axles...
My full-spool has yet to fail me, but I really hate it on the street! I keep up because it's less moving parts to break and just not drive my EB on the street much.
- newracer
The only reason why I am considering not going to a spool is I have cutting brakes. Even though I have yet to use them I'd like to keep the function just in case. I could go with an ARB, supposedly the strongest locker for a 14 bolt, but it's twice the price.
- 74BuckinBronc
- Contact:
Yeah, I see your point. Cutting brakes are a great feature. Are there any other selectable lockers for the 14b? I dislike the failure rate of the ARB (usually some seal or air line issue).
- newracer
- newracer
- newracer
- tjjared413
- newracer
- newracer
- newracer
Not yet. I had to order some tall jack stands to support the rear while I remove the axle housing, they should be here any day. Also found the outer bearing on the hub is cracked. Going to take the housing to Sessions Motorsports and figure out the best way to repair, either weld on a new spindle or get a new housing.
- newracer
- tjjared413
- newracer
- Sam I Am
- newracer
- tjjared413
- newracer
Took the housing to Sessions Motorsports. After checking the housing to make sure it was straight and there were not any other issues we decided to cut the spindle off and weld a new one on. The other option would have been to move all my parts to another housing. The housing and spindle are at the machinist now so they can be machined for a perfect fit then it will be welded. Housing might be ready to put back together by the weekend.
- tjjared413
- newracer
- newracer
- tjjared413
- newracer
- Aaron
- Contact:
- 74BuckinBronc
- Contact:
Vroom!
- vb
- newracer
- vb
- vb
- newracer
- newracer
- newracer
