Woohoo! Congrats! Bet you are itching to get outnewracer wrote:Caliper bracket is now fixed. Just a few minor things to do and it will be back to 100%.
New to me buggy!
- Aaron
- Contact:
- tjjared413
- newracer
- tjjared413
- newracer
- tjjared413
- 74BuckinBronc
- Contact:
What? No pics?
- newracer
- 74BuckinBronc
- Contact:
Must be the first one posted this year? Congrats!
- newracer
- newracer
- Aaron
- Contact:
- newracer
- 74BuckinBronc
- Contact:
Nice!
No leaks for me means something is empty...
- YJgirl
- Contact:
If that doesn't work try some Heatshield Product.newracer wrote:The two main firewall panels would get really hot, ~150*, after running for a while. I tired some thin stick on insulating material with no luck. Got some leftover Lizard Skin from Nimbus to try. I think it will do the job.
TRAIL HUGGER - Enuf said.
- newracer
The Man With The Plan
It always ran hot for me too. I'm beginning to think that it may be the tune. It's a MEFI4 with a tune copied from another engine. Might be Wyeth looking into.
Sent from my SM-N950U using Tapatalk
Jon, AKA The Man With The Plan, ΜΟΛΩΝ ΛΑΒΕ Illegitimi non Carborundum = "Don't let the bastards get you down" Micris Fidelis="Faithful to small things" And it's an anagram...I'll let you figure it out
- newracer
Crawling was never an issue. Higher speeds generally brought the heat.
- newracer
- 74BuckinBronc
- Contact:
Was the coil rubbing on the shaft? How does a coil get bent like that??
- newracer
- newracer
- newracer
