So some background the passenger side motor mount sheered breaking the distributor.
So far we have replaced
- Distributor
- Spark Plugs and Leads
- Crankshaft sensor
- Camshaft sensor
- MAP sensor
- ASD Relay
- PCM
- Injectors
- One of the injector connectors
- Coil
- Starter
Checked all the fuses in the PDC.
I suspect the timing. If we pull the distributor and place it back in without the pin in we can get it started but its rough, yet I thought all the timing was set on the PCM with the distributor pin in the first hole.
We checked TDC and that looks good Cyl 1 top with the markings in the right place etc.
Starting to look through wiring diagrams incase anything caught my eye but thought I'd ask here for any ideas as I an running out of them.
Anything special with replacing the distributor ? We removed the old one set the engine on TDC , set the oil pump to about 11 o'clock the distributor dropped in ok rotated clockwise on the gears and the mounting lug lined up without issue.
thanks Jon
