New to me buggy!
Aaron
Post by Aaron »
newracer wrote:Caliper bracket is now fixed. Just a few minor things to do and it will be back to 100%.
Woohoo! Congrats! Bet you are itching to get out
tjjared413
Post by tjjared413 »
So close!
I’ve thought about cutting the spindles of mine and converting to unit bearings with some weld on cups...
newracer
Post by newracer »
Drove the buggy around the block a few times and flexed on the big snow pile on the side of my driveway, everything is good. Also tried the parking brake valve, works great.
vb
Post by vb »
Congratulations
tjjared413
newracer
Post by newracer »
Ran Independence, Patriot and Liberty today, no issues. Glad to be back on the trail.
Colo.TJ
Post by Colo.TJ »
:thumbsup:
tjjared413
Nice
74BuckinBronc
Post by 74BuckinBronc »
What? No pics?
newracer
Post by newracer »
74BuckinBronc wrote:What? No pics?
Started a trip report.
74BuckinBronc
Must be the first one posted this year? Congrats!
newracer
Post by newracer »
Used my old rock lights for in-cab lights.
Switch
4 lights in pairs up front
4 in rear
newracer
Post by newracer »
Also got a steering wheel hook.
vb
Post by vb »
The thing looks good!
Aaron
Post by Aaron »
Great repurposing of old materials. Will make night wheeling so much easier. And I love the simply machined hook for the steering wheel. Nice and clean.
Good work! :beer:
newracer
Post by newracer »
At some point this summer I damaged the shaft on my hydro steering which caused a leak. So I took the opportunity to upgrade the ram. I also had a shop add a piece of tube to keep it from happening again.
vb
Post by vb »
I dont like leaks either
74BuckinBronc
Nice!
No leaks for me means something is empty...
YJgirl
Post by YJgirl »
newracer wrote:The two main firewall panels would get really hot, ~150*, after running for a while. I tired some thin stick on insulating material with no luck. Got some leftover Lizard Skin from Nimbus to try. I think it will do the job.
If that doesn't work try some Heatshield Product.
TRAIL HUGGER - Enuf said.
newracer
Post by newracer »
The lizard skin helped but it would still get hot. I added some rubber floor mat on the exterior that has made it tolerable.
The Man With The Plan
Post by The Man With The Plan »
It always ran hot for me too. I'm beginning to think that it may be the tune. It's a MEFI4 with a tune copied from another engine. Might be Wyeth looking into.
Sent from my SM-N950U using Tapatalk
Jon, AKA The Man With The Plan, ΜΟΛΩΝ ΛΑΒΕ Illegitimi non Carborundum = "Don't let the bastards get you down" Micris Fidelis="Faithful to small things" And it's an anagram...I'll let you figure it out
newracer
Post by newracer »
The motor runs fine, about 200* while crawling, just the firewall gets too hot to touch.
Crawling was never an issue. Higher speeds generally brought the heat.
newracer
Post by newracer »
One of my shocks was leaking oil so I decided to rebuild them today. Unfortunately I found some damaged parts.
74BuckinBronc
Was the coil rubbing on the shaft? How does a coil get bent like that??
newracer
Post by newracer »
I am not sure. Thought is the slider between the two coils got stuck and then the lower coil was over compressed.
Man, the previous owner must've beat the $#!+ out of that thing.
newracer
Post by newracer »
Tell me about it. :rant:
newracer wrote:Tell me about it. :rant:
Rofl
newracer
Post by newracer »
The fuel pump was external and right behind the front seats, very noisy. Took it out, relocated filter and shut off valve, added a Holley Fuel Cell module, much better.
Also cut a roof decal.
This is the way
