I started today intending to dive right in to cutting the frame and the donor frame. I wasn't happy with the temp x-member I welded in last night because it would be in the way of fixturing the two frames together, so I decided to weld in a new one. My bride was using the dryer and I'm ashamed to admit I've been in this house for almost 4 yrs and still no 220 in the garage. The only 110 welder I have is a TIG, so I got to do a little TIG work in the driveway. No big deal except for the constant 3-5 kts of wind and the occasional 8-10 kt gust. Not real pretty, but not too bad. My 5 yr old watched and he approved.
I've been researching this dumb idea for a long time and thought I had every angle covered. Right before I was about to cut the TJ frame, I stepped back and looked it over and thought there's no good reason to no test fit the tub and fuel tank now. So that's what I did. I have a Genright Stretch tank for a YJ, which ALMOST fits. The studs for the 2 straps were interfering with the crossmember in front of the tank.
So I notched the crossmember for clearance.
Now no problems fitting, but I had to match drill a few new holes in the gas tank skid that didn't match. I think 3 out of 7 lined up.
I was able to reuse 6 out of 7 of the bolts. The 7th was off on the flange for the skid altogether, so I drilled a new one. I have to remember to weld the bolt in place from above because I can't get to the head with the tub in place.
After I got the tank to fit, I tried the back half of the tub I cut off.
No problems with that fit. I had some concerns with the upper coil mounts based on my bad memory working on a bunch of TJs in the past, but no problems.
Then I moved on to getting the last measurements I wanted, maybe even needed before I cut the frames. I wanted to verify the distance above a known point, with the frame level, to the aft-most body mount point on the frame. I figured that the fore-aft position, and even the left-right were fairly easy to dial in, but the vertical position of the aft body mounts could be problematic.
To do this I first leveled the belly section of the frame.
Then I took a laser level and drew a line through the top of the body mounts at the middle of the door and the next one aft.
Once I had established this line, I measured from the top on the aft body mount down to the line.
I also put a couple pieces of tape with a mark where the laser line was for reference later.
The figure I came up with is about 3/16" off from the YJ frame drawings available all over the web, but I'm hoping it will be useful.
My plan is to duplicate this with the new frame section in place to keep the aft crossmember properly aligned vertically. The reality is that this may be picking fly shit out of pepper, but worry about the ounces, and the pounds will take care of themselves.
After I'd recorded all of this nonsense, I got to cutting. No pics of that because who cares? It's just a cut up frame.
Here are a few pics where I left it with the section of TJ frame roughly in place where it will end up.
Time for beer...good night
