Pro Comp 2x2 Cube Light ?
CJNUT
Post by CJNUT »
I can't seem to find anybody that can directly answer my questions... I have a set of PC 2x2 LED cube lights on order I want to put in my Poison Spyder Bruizer frt bumper, it has the square cut outs. I would like to connect them to the factory fog light wiring, so I can use the turn signal for on/off on my 2015 jk. Nobody can tell me if this work correctly or not, will they flicker, do I need to use the relay that comes with the PC lights or will the factory wiring be enough? I even called Pro Comp and was told that the relay that comes with the lights will be enough. He said if they flicker the relay will prevent it from happening. He didn't sound convincing enough to believe him. TIA
Bill
newracer
Post by newracer »
I would use the factory wiring to trigger the relay. JKs are notorious for being finicky with aftermarket electrical items. As far as flickering you'll just have to try it and see.
CJNUT
Post by CJNUT »
I will try that... thanx so much
Bill
