First and foremost, staying on the trail is critical to keeping our trails open. I would like to give a brief overview on what Staying on the trail equates to. Staying on the trail means staying on the main road corridor. Recently there were photos of a group that were driving over boulders in the trees, pulling down trees, driving on vegetation, and drinking. Driving over boulders that are not located in the main road corridor is going off trail. Driving through the trees that is not on the main road corridor is going off trail. Creating a new line on a trail is going off trail. Destructive or harmful acts to vegetation and landscape, especially marshes, is not only going off trail but you are also destroying an ecosystem that is vital to nature and human survival. Drinking and driving is illegal and can result in a DUI regardless if you are on an OHV route or not.
Driving up a creek bed is not off trail as long as you exit the creek bed in the designated spot. If you stay on course, you won't have an issue. An alternative deemed by someone before you, or you yourself that is not the main entrance or exit is where problems begin. Watershed is the one thing that closes trails the fastest. If the road corridor within a creek bed is not maintained and monitored, and all users do not follow the precise instructions on exit placement, the walls of the creek bed deteriorate and that in turn will cause drainage problems. A perfect example is Carnage Lefthand and why it is slated to be closed.
Driving on a snow drift is not off trail until your tire makes contact with dirt or some form of vegetation that is not in the road corridor. This does not mean driving cross country is acceptable by any means, it simply implies that if you slide off the road corridor when snow bashing, get back on the trail. Again, if you leave the road corridor, you are off trail.
Pulling off to the side of the road to break for lunch is not going off trail. However, parking on top of bushes, trees, and other areas that it is clearly unnecessary to park on is going off trail. An easy way to remember where good locations are to park for lunch or a break is to think about what your mom would say to you if you parked on her lawn. The grass is probably okay unless it is really muddy, but the flowers and bushes she is most likely going to beat you with the broom handle.
Foremost, we all need to remember that we 4-wheel to have fun, we do not 4-wheel to be destructive or to be judgmental on others, so be mindful of yourself, your actions, and your posts and we can all work together to keep trails open.
